When is it OK to wax a new vehicle?
Jm91rs
Cincninati
I know paint technology now is not what it was when I detailed cars as an 18 year old. How soon after manufacturing is it OK to wax my new Ram? The truck was built 2 weeks ago, would love to get a coat of wax on there before winter hits.
*edit* I use paste wax if that matters. I've tried tons of other things, I just like good old fashioned paste wax best.
BWL
Embrace the skeptisism
BC Canada
Should be no problem waxing it right away. Pretty sure everything is painted and baked pre assembly and with the paint and ovens they use at the factory a couple weeks would be good regardless. If you're concerned then wait a couple more weeks.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I added a ceramic to mine a week after owning.
yakalong
KC
I waxed mine within the first week of owning it.
jeffrey5679
Lake Stevens
Hemim 5.7
I would decontaminate the paint with iron x, claybar, then seal/wax it even though it's new. mine had alot of contamination in the paint straight from the dealer
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
Did mine today - two weeks after taking ownership and was manufactured 27 August.
It is white and needed decontamination/clay bar and wax due to the rail dust.
Narg
Tulsa, OK
5.7 eTorque
It's crazy how dirty these get in transport to dealerships. You should see them getting off the hauler, would make you cringe.
luckydog
eastern Pennsylvania
It's definitely ready for wax. Like others have said, I would clay bar or clean it first- like in the old days there is no reason to seal in the dirt!
Killface3
Stansbury Park, Utah, U.S.A.
345 HEMI
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
Interesting this topic came up...just the other day I watched a YouTube video comparing Clay bars to plumbers putty...plumbers putty was equal(as per the guy)and cost way less than the name brands.
OC455
Central NY
Picking mine up from the detailer in a bit.
OC455
Central NY
The guy thay did the detail work on my 3500 said that there was metallic particles that covered the whole truck when he went to clean it. I guess he uses a chemical thay is supposed to neutralize the contaminants or something like that. He said he sprayed it on and then it turned a purple color from the metal particles on it....
Probably shipped on a rail car
rotts4u
chattanooga tn
5.7 e torque
There are so many products that are better than plain ole "paste wax". Easier to apply, last longer, look better etc. Please consider using a modern paint sealant or even a spray on sealant will outlast the paste wax and its a lot easier to use too.
shanmccarthy
