Where have you installed switches???
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
Whats behind it on us 8spd owners
Here is where i mounted my light bar switch
Rampaige
Seeing how I use my LED light bar for my high beams (back roads) I had to mount it for quick & easy access.
jenham
How hard is it to get the radio panel out
Sent from my LG-H918 using Tapatalk
Pop cover off top tray and remove two screws. Think there's a screw in the back of the cubby hole above where he mounted the switch. If You have a centre console that has to be removed as well
Demon-HeMi
Houston
my truck didnt have the screw in the bottom cubby, only two on top and then just pull
zogg
Southern Illinois
2018 Ram Express Quad Cab
picture.php
I did exactly the same this as this.....easy access. I also installed an led light next to the switches as a reminder to turn them off...hahha
smokedbystang
Central Florida
2012 Ram 1500 Express 4x4
I need to get that blank cover. Mine is a small cubby that I cut the back off to run the wires. I just stuck it in there. Works but doesn't look all that great.
Deepc6
Long Island
Hemi 5.7 Etorque
Does anyone know where I can get a rocker panel cover for the small cubby on the passenger side of the stereo under the vent?
ckeefer58
This spot works great for my '13 (6spd) because there is nothing behind it and it is a $5 panel to replace if I ever need to take the switches out.
Red switch - LED light bar on grill guard
Green switch - unused (for now)
Blue switch - rear LED pods
You wouldn't happen to know the part number for that panel would you?
Sent from my Nexus 6P using Tapatalk
TRXHemi
Sugar Land, TX
Under the steering wheel to the right a little. Switches from Otrattw.com.
15RamTX
If you call the dealership and ask for a manual park release cover its 7$
MoreOvalteenPlz
Stillwater, OK
1WA33TRMAB is the part # for my 2013 with the black colored dash. That number may/will vary depending on truck year and dash color...
tylerlewis_89
I have a 2011 with centre shifter here's a pic of where I put mine there's only enough room there for about 3 switches
2011 Laramie crew,295/65R20 Toyo AT2s extreme,bully dog tuner, led light conversion inside and out, iron cross bumper,12,000lbs warnwinch 1/2" spectra line,levelled,red bumper halos with led fog lights,black grills with led pods behind
EVc96bKA
So is there no way to utilize some of the vacant button spots on the factory panels? For example, I don't have a sunroof but I have the panel available with vacant button spots. I just always assumed one could pop or cut out those button spots and add some type of aftermarket switches. Similar spots exist down by the tow/haul button area.
Jaded
Southern Maryland
This was also my thought. I don't have the buttons for the sunroof but i do have like two extra on my area by the HVAC controls that would be nice to use.
EVc96bKA
Check this out.
http://www.ramforum.com/1577962-post12.html
JRam5.7
Treasure Coast FL
5.7L
I'm hoping this setup will work for my front camera and lightbar, 2 latching led 16mm buttons under the shift dial....
MikeTastic
Mobile, AL
Anyone have a part number for the cover under the light switch for a 2011? I have the cubby.
thoffmann517
