where is the security module 2020 ram slt?
lAWROSA
GALIVANTS FERRY SOUTH CAROLINA
Cant find it. I looked behind radio, behind cluster, and looked hi and low under dash. Its not there.
I have a ticket into infotainment .com where I got the brake controller from.
If I have to get it flashed I want a partial refund. As the fauking controller was like $500 bucks.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
It is way up under the dash towards the emergency brake. The view might be partially obstructed by a harness or two but it is there. I recently did a remote start install on a 2020 classic so I had to install the M2 Mods security bypass. Once you figure it out, it takes a few seconds to connect and disconnect.
Tach_tech
5.7L HEMI
If you’re talking about the security gateway module it’s behind the radio.
Dodge 1500 4X4
Rochester, NY
Your truck is a 4th gen as @Tach_tech stated it's behind the radio, 5th gens it's behind the headlight switch, where did you get your cable from, did you get the cable from here, the vendor has a diagram to its location and how to install it.
robinsontech
TEXAS
2020 1500 Classic 2WD
I purchased one from Amazon. I was hoping it wasn't behind the radio. Oh well.
