Who has upgraded their RA4 Radio
Rockshooter
Tonganoxie KS
Having problems with my navigation 2014 R/T.On the fence with repair or upgrade.Would like to hear your thoughts ,and experience 's with up grades.
Thanks in advance Rich
Rockshooter
Rockshooter
Tonganoxie KS
tron67j
Maryland
You are in the wrong generation, try going to the 4th gen section and read the stickies under audio. You will find topics on both upgrading software and replacing your radio. I recommend you read through them all first as they contain a lot of information that will be incredibly useful no matter what you end up doing. Yes, a lot of material that may not be exactly related, but you will learn to skim through as you get the hang of how the threads flow. And yes, I did the slog through as well when I upgraded my basic radio to a UAS in my 2018. A lot of very knowledgeable people spent their valuable time answering the same questions you have, and that you will have. And I highly recommend that if you need wiring harnesses or other gear that you visit and purchase from the awesome vendors like M²Mods. Trust me, worth the money for the follow up help they give versus maybe saving a buck elsewhere and then coming back here for help because the seller won't return your emails. Good luck.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Worth it to upgrade to the UAS/UAQ in my opinion. What's going on with the NAV on yours (what symptoms)?
ChloeBrooks
