Who's got the most miles on there truck!
P
PIPTHEREDRAM
5.9 magnum
Just realized I haven't said anything about my truck.
98 5.9 4x4. Its got 191,000 on it and the only major thing I've done to it is rebuild all the steering, although I think someone has rebuilt the tranny with a shift kit. The lady I got it from only had him for a few months before realizing the mechanic wanted to much to fix the steering so I basicly stole it for $600. I'm guessing im the fourth owner. Someone along the line did some crappy work to the truck such as installing a brake caliper with only one bolt on both sides! And completely stripping an axle nut to name a few. I plan to drive it for as long as I can then stick in the yard as a lawn ordament, then find another great 2nd gen.
DodgeLady
AZ
5.9 L
Drum roll please! 315K. 5.9 L 2WD 1997 ext cab short bed.
Replaced water pump, alternator, usual maintenance things. Also had to replace the harmonic balancer.
Engine plugs blew out right after I bought the truck in 1998 at 36,000 miles. That I understood was a factory defect Dodge knew about.
It’s in the shop now getting a new heater core and Freon core ( not sure if I’m using the right term there...)
Heater core had been bypassed but will get replaced with the work on the heat exchanger.
DodgeLady
AZ
5.9 L
Oh! And while we’re doing the heater core etc I’ll put in s new lmc dash pad!
DodgeLady
AZ
5.9 L
Yes for the plugs.
Trent
Demi 5.7
2015 Dodge RAM 1500 has 220,000KM (136,700 Miles). Replaced tie rod and wheel bearing.
P
PIPTHEREDRAM
5.9 magnum
01 quad cab 5.2 off road. Sold it at 295,000 a year and a half ago and I see it on the road once a week still. Trans at 70,000, rear pinion seal popped and lost rear end at 215,000.[/QUOTE
Do you ever wish you hadn't sold it since you see it every week?
Floyd1979
Well on Gas motor I might be in the lead —- 430,270
2009 Dodge Ram , Hemi 5.7
Crewcab,
THE 2009 came with lifetime power train warranty, purchased lifetime Maxcare for 1800.00. / 100 deductible
430,270 on the clock , Original power train .
Front end all original (shocks)
Heater core
Drive shaft
Wiper motor
All hoses
Around 225,000 1st items went out
Fuel pump water pump
Around 325,000 MDS went out
While in there they replaced cam and lifters.
Ac compressor
Exhaust bolts
Alternator / PCM
Fuel pump -# 2
Rear axle recall 2xs
400,000 - radiator, thermostat, water pump ,
Blower fan
Blending door 2xs
DodgeLady
AZ
5.9 L
Crewcab,
Heater core
Drive shaft
Wiper motor
All hoses
Ac compressor
Exhaust bolts
Alternator / PCM
Fuel pump -# 2
Blower fan
Blending door 2xs
Wow! I’m impressed! I’m getting kind of nervous here though... reading about all that CAN go wrong in a truck! It’s an education for me.
(I’m at 315k on my 97 5.9L)
