why is my truck squeaking?
Diedrich'sDodge
WI
5.9L 360 Magnum
So recently I had an O2 sensor go out and right when the sensor quit I started hearing a squeak that sounds like its coming from the passenger side of the truck, it only happens when I first press the gas pedal and when I let off the gas pedal it also happens when I shut off the truck.
My truck was burning oil for a while could it be a clogged cat?
Any ideas on what it could be?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
My first thought is something rubbing up against the exhaust. An O2 sensor going out won't cause a squeak unless there is something rubbing, like I said. The only other thing I can think of would just be a coincidence.
Diedrich'sDodge
Diedrich'sDodge
WI
5.9L 360 Magnum
I have looked all around the exhaust and even fastened down the heat shields hoping that would fix it but the squeak is still there
The squeak almost sounds electronic
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Electronic squeak....sounds like a band. :D
Does it happen all the time or only when turning or whatever?
Diedrich'sDodge
Diedrich'sDodge
WI
5.9L 360 Magnum
Haha ya kinda
It happens any time whenever I hit the gas pedal or let off, it also does it when I turn the truck off
