New here. I have a 2015 ram 1500 outdoorsman edition. I am installing a readylift 69-1040. Will 295 65 20's fit on stock rims without rubbing? 20x9 black wheels
I can't even fit a finger between my tire n UCA... 18x8.5 15+ offset 35x12.5... I ma y be interested in the spacers? Not sure,I have 35-12.50-20 BFG KO2. When I first put them on I had Rancho quick lift. That gave me about 2.25" lift. I have the 20x9 chrome clad with NO spacers. I bought the 10mm Hubcentric spacers to be sure when the tires were installed I could drive home . After a couple days I removed all 4 spacers and never used them Again with no rubbing any wheres. Thats better than $200.00 sitting in a box now. I since went with Bilstein 5100's, 3/4" spacer in the rear and a 1.5" zone body lift so it is beginning to look like a 4x4
For what it's worth, I had to add 1" spacers because it was rubbing on my Outdoorsman. But, that was with about 2" up front, so you might be fine if you're lifting it higher.Also measured from tire to uca. I have 7/8". Should be good without the spacers. Maybe I'll use them anyway or I'll take a loss and sell them cheap to someone with 20x9s. Thanks for all the help! I'll post pics soon
I couldn't fit a finger between my sidewall and end of upper control arm when it was stock. I have thrown it onto ext ramps at well above the speed limit to see if I could get a rub just to be sure and got noting. That was also at about 36lbs of air in the tires. You are probably fine now .
I cant fit more than my pinky nail between uca knuckle and tire now with 33's stock. I think because my uca is rough country bigger than stock uca. So any bigger tire not possible without spacer... :-(
Not sure what 10mm spacer i can get i dont want spacers with studs....
