Will 35 X 12.5 R18 fit on my truck?
Hugeez
Union, MO
6.4 HEMI
Hello. New to your website. Recently purchased a 2017 Ram 2500 Laramie 4 X 4 with the 6.4 HEMI. The truck came with OEM Firestone 275 70 R 18 tires. This is a 33.2" tire that is 10.8" wide. The truck is stock heighth. My question is can I fit a 35 X 12.5 18 tire without it rubbing? I know it will fit on my 9" rim ok just not sure that I can turn the steering while from lock to lock without the tire rubbing in the tire well.
Thank you in advance...
Murder_ram22
Level it in the front and you will be good with no rub
Sent from my LG-K540 using Tapatalk
Murder_ram22
Just realized you have the 4x4 not sure it might already be level but if not it should be about 2 in difference
