Will an Autel SGW bypass work with AlphaOBD? And the MX+ adaptor
rceagle1a
Central Iowa
I've used multiple search parameters with zero concrete info. Will an Autel SGW Bypass work with a MX+ and alphaOBD on a 2022 Ram2500?
RamDiver
Marlborough, Ontario Canada
2021 DS
Yes, a 12+8 security bypass cable will work, but it has to be R&R each time you make an adjustment.
More importantly, where is the SGW module located on your truck?
Mine is buried behind the radio; I'm not interested in that grief.
Several gen 5 trucks have the SGW beside/behind the OBD2 port.
The KaodTech Security Gateway bypass harness connects to the CAN bus blocks, beside/behind the OBD2 port and most importantly, install it and forget it.
I installed mine over 2 years ago. :cool:
https://kaodtech.com
R
rceagle1a
Central Iowa
I would love to have ordered from them but they are out of stock.I have one coming from infotainment.
RamDiver
2021 DS
They always show as out of stock as they're made when ordered.
Mine was received PDQ, IIRC.
Have you confirmed the location of the SGW for a '22 2500?
According to this video, it's buried behind the EVIC.
I have no affiliation with KaodTech, but I would kiss the money you spent at Infotainment goodbye, save a pile of grief, and order a KaodTech harness. :cool:
Please update your avatar to show the 2022 2500.
TIA
joesstripclub
Kansas City, MO
2021 2500 PW
Mine is behind the gauge cluster. After removing half the dash to get to it and use that bypass cable, I bought one of the kaodtech cables to not have to go through that mess again.
