Will I need spacers?
lucky8926
Eventually I plan on leveling the front of my 2014 2500. I then plan on getting 35x12.5 tires. I am going to keep the stock 20" rims. I'm not sure the width on them though. My question is, will I need spacers to clear the 35x12.5's?
cyclepuck
2014 2500 Mega
Stock 20's are 8" wide. Planning on leveling mine in the next few months but thinking of going to a 295/65r20 tire. Almost 35 tall but an inch narrower.
Sent from my SM-G928V using Tapatalk
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
No you won't need spacers to run them but they will rub the sway bar and likely the radius arm near full lock. If you want to avoid that you can run spacers but you'll want 1" spacers max which will require you to trim your studs down.
