Win Module with Remote Start
Jokeascool
Ocean View, Delaware
Hello All,
First time poster with a question.
My 2012 Ram 1500 has a bad WIN module that will not allow the truck to start. I am working on ordering a replacement. My current WIN module has remote start. When I replace the module, does the new one need to have remote start as well?
I do not use the remote start and it is not a necessity.
Thank you in advance!
rule18
Admin
NY
2017 Rebel
@Jokeascool Welcome to RamForum. I've moved this thread into a higher visibility section.
Burla
2010 Hemi Reg Cab 4x4
You can bypass that win module if desired, see below vid. Yes you need to get one compatible with remote start, those cheap less the 200 buck models dont support remote start, and likely have to have it programmed by a dealer or locksmith either way.
You can see some are labeled remote start.
