Window auto switches
ddetta88
SLC, UT
Has anyone ever swapped the rear window switches in the driver's control panel to auto switches?
Is it even possible?
I've been wondering the same thing hope someone has an answer
Sent from my Z981 using Tapatalk
D
ddetta88
SLC, UT
Based on photos of the back of the panel you can take it apart. I might pull mine apart and see how it looks if I do I'll post photos
00R/T
CT
The switches are just switches. There is an extra pad on the PCB for the auto position, which I doubt is going to be there for the rears. Regardless, you also need some sort of module with logic to detect the stop position and automate the control. On the front doors this is built into the door modules.
