Window Lock Button - Front Passenger Side Window
JPT
NY
2015 Big Horn
When you press the window lock button, is there a reason that the front passenger side window doesn't lock like the rear windows?
I'm guessing this is how it was designed, but seems like when the driver locks the window controls, only the drivers controls should work...
tma777
I believe that is how it is designed, mine is the same way only locks the rear windows. I believe it is along the lines of the child safety locks on the rear doors, when engaged the doors can only be opened from the outside which would make sense for the windows in the back to be locked as well.
JPT
JPT
NY
2015 Big Horn
I think that is a bad design... It should lock out all window controls except the drivers controls.
Thanks
