Window tint
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
I'll be getting the fronts tinted at 35% and the tinter uses Suntek and SolarGard films. Which do you recommend and why? It will most likely be a carbon series film. Thanks
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
SolarGard...better scratch coat by far.
mitey22
Georgia
I heard somewhere on here 20% is the factory can anyone confirm
rendrag09
I'm getting mine matched tomorrow with a visor strip and they said 20% is what they match factory with.
Also, not to hijack your thread, but how is Llumar tint? It's the ceramic lifetime warranty stuff.
96ram1500
PA
The guy o get to do my windows ises 3m an 1 other type I'm unsure of. He did all my windows with 3m an I have never had any problems with it. My front two are currently at 5% an my back two doors an back windows have I do believe 25% over the factory tint which took it down to 5% so it is the same all they way around. I do have a 5% eyebrow also but I then got vinyl to match the color of my truck an put that on the outside.
rendrag09
This is 20% on the front with a visor strip
rendrag09
It matches pretty well I can't see a noticeable difference. I would just tell whatever shop that does it that you want it matched. They'll know what percent matches for the tint they use.
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Found out today that the tinter i had talked to actually uses flexfilm. I read reviews about the Teraflex line and am skeptical. Early reviews were good but recent reviews say over time it fades. Any opinions? I only want to do it once with a quality product. I'm open to suggestions. Thanks
rendrag09
Llumar Ceramic tint has a lifetime warranty, as long as it isn't your fault they'll replace it. Not sure what else is out there. I would be skeptical too. I've seen too many tinted windows looking purple because of ****** tint.
GRB60
Harleysville PA
Hemi 5.7 e-torque
My guy said the factory tint is 18%, so 20% will be close enough that you can't tell the difference. I went with 35% so as not to get the attention of the police and to pass inspection, which can be an issue here in PA. He uses Llumar films and has for a long while. They hold up very well.
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Decided on a shop that is going to install Llumar Formula One Pinnacle 35%. It's more expensive but everything I read about it says it is a high quality film. I only want to do it once.
