Windshield washer help
lynchburg14
Newport News VA
2011 1500 Crew Cab
When I hit the button for washer fluid it only comes out of the driver side, and that is not as strong as it has been. I have cleaned out the other side but can't get anything to work. Is the pump going bad or something else maybe? Is it hard to replace the pump if so? I tried to follow the lines but cant trace it back to the pump because of all the stuff in the way.
Crashno1
South Florida
2014 R/T
I had the same problem. The passenger side nozzle might have snapped. . Lift the hood and hit the spray, fluid will run out from behind the insulation.
Lowrider357
