Well hate to say it but winter is here and when I lifted my truck and got new wheels n tires I ended up giving my old ones to a buddy in need, I did plan on getting a set to out on for the winter and still am because in the northeast the salt is crazy...but in the meantime is there anything that you know of that you can coat the wheels to protect them from the salt and road grime til I find a set....thanks
Wipe them down with 80w90 gear oil. It stays in place. But in an attached garage it will have the odour of gear oil.
A quart of 80/90 is about 10 bucks. All you need us rubber gloves and an old wash cloth
I have used it for decades in my fender wells, rocker panels etc as well.
Drill a hole in your fender well from inside the box directly in the middle of the wheel well just up the side a little and shoot about 3 or 4 oz of it. In there. It will climb the sheet metal and do it every year and your wheel arches will never ever corrode
Do your door cavities and you can access your rockers by drilling into to B post. Use a 1/2 hole saw and snap a zinc plated electrical box plug into it and it looks factory.
They will also never rust.
If you can't park on dirt then put cardboard or old carpet under it for a week.
The oil is cheap so don't be [emoji4]
Sent from my CLT-L04 using Tapatalk
