Wiper blades
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Just curious if anyone else has tried replacing the factory blades with 22"ers? Everything I read said the truck takes 22" blades but when I tried them they'd end about an inch short of where the factory wipers would wipe. Was driving me nuts so I got 24"ers and they match the factory blades perfectly.
bryce88
Utah
Hmmm interesting. I replaced them with 22" blades and didn't notice a problem. But as long as 24" blades don't hit anything weird I don't think it'd be a problem to use them.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I would think think 24-inchers would be too long as the new 22 inch Trico Force blades I got fit the same as the stock blades. Even look the same as them, too. The passenger side one on the end doesn’t touch the windshield when they’re all the way down. They work great, tho. Much better than the Bosch Icons I had before.
brianw0048
EcoDiesel
I put 22" Bosch blades on mine and they seem like theyre shorter than the factory blades...
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
I got Bosch Envision. The 24s are one inch longer at each end. The passenger end also doesn't touch the windshield when it's down either. The 24s seem to be the same as factory.
corneileous
Podunkyville, OK
What’s the difference between those and the Icons?
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
I found the 24” factory style blades to hop a lot across my windshield during light rain at highway speed. I finally replaced them with 22” factory size Bosch icons. The icons are awesome! They are smooth and seamless all day.
huntergreen
Marine Corps Navy Badge
Is it just me, or does it seem like a real waste to replace the whole wiper and not just the refills like we used to?
Can we still by refills ?
Ratket
Arizona-
^ prolly not... they got to maximize profits lololol
Wahrsuul
Central S.C.
Not that I know of - unless someone has some NOS stock laying around.
corneileous
Podunkyville, OK
I think they still make some of the traditional wiper blades with replaceable blades. As far as whether or not the stock Mopar blades, the Bosch Icons/Envisions, Trico Force, or any of the other higher-ended blades are made to replace just the blade part, that I don’t know.
But I would think the blade companies think only people who buy the expensive blades aren’t worried about replacing just part of their blade, instead of the whole thing. And that only the people who buy the cheap blades are the ones who obviously want to spend as little as possible on blades, and maybe that’s why they make most of the cheap blades able to just replace part of it....
Wahrsuul
Central S.C.
I haven't seen refills available anywhere in several years.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I always have the dealer replace the blades. That way, when they chatter, I can blame them and they can deal with it.
geneseedennis
