Wireless Back Up Camera
sausec17
Banned
ATLANTA
Anyone use any of these? I heard the digital transmitters are better since they don't run on 2.4ghz, which may interfere with Bluetooth and Wi-Fi.
Also, looking for a reliable camera, with a wide field of view and night vision.
Thanks!
baum
savage, mn
2015 Laramie
I currently have one on my ram.. as i was too lazy to run the wire along the truck. yes they work, but no the the best. there is some interference once in a while. seems to get worse when its cold. im in minnesota so i get alot colder than you..
when i get some time this summer i will be running the cable. part of my issue is i went of of the 7 pin harness for the reverse trigger. they may work a little better if you ran it off of an ignition feed so they are "live" and focused when you go to reverse.
most BU cams get nice pictures at night also.
