Wiring help
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
I have a question for the wiring experts.
I bought some rigid duallys. I wired them up and they do not turn on. This is not my first set of light I have wired. I am absolutely eff'in lost.
Look at the diagram below and you will see just how easy of an instal these lights are.
Again, won't turn on. Suggestions please. I am losing my mind. Thanks.
muscleram
Start at the lights check for power and ground. Flip the switch see what happens. If you got nothing go back to the switch and check for power and ground. Also check the fuse even if it looks fine check it with a test light
Sent from my SM-G935W8 using Tapatalk
baum
savage, mn
2015 Laramie
I also would start at the switch take a dmm to the terminals at there and make sure you are getting the 12+, ground.
HemiPower36
HemiPower36
CA
Thank you all for the feed back.
HemiPower36
HemiPower36
CA
Turns out, had a blown fuse. I think I caused it. 99.9% sure. Not a rigid defect at all. :)
