Wiring issue
wizard0958
I have an 07 ram 1500.i had to play around with the wiring in the drivers door to make locks and windows work at switches. After replacing the harness, if i hit the back passenger window, the front passenger window operates. The locks don't go up and down but it sound like the actuator is working. They worked before i changed it the harness. Any ideas. Thank you.
GB55
Maryland
sounds like you have some wires crossed in the harness. what all did you replace/swap out? was it an OEM replacement harness or something you built?
W
wizard0958
The harness was OEM. That's why it is so bothering.
Atcer2018
Virginia
But is it the correct OEM harness? Did you order it from a dealer parts department or was it from a salvage yard that someone said would work? Sounds like you may have the wrong model harness.
blue ghost
Pennsylvania
2013 Ram 1500 sport
Take a look at the wiring colors at the plug to make sure they match up there are so many versions for the harness(also check with the old harness). If that's ok, look for where the wires may have gone over a sharp metal part of the door.
W
wizard0958
I thank you. I hope that I can get a result here pretty soon. Pulling my hair out.
