- Jan 5, 2011
- 13,081
- 28,485
- 2016
- hemi 5.7
I doubt it is the cats. At 140000 miles I believe your valleys and sensor pack, one unit, are in need of replacement.
Had similar problem with my 2002 Ram quad cab. Problem ended up being the transmission though, required a rebuild and the problem went away. good luck.so I have an 05 1500 4.7. I noticed that when I came to a complete stop and went to accelerate , the truck Rpms would go up but the truck would crawl slowly. I would have to gradually build up speed . The plugs and coils have been changed. O2 and TPS sensors changed within the last year. Only code is a loose gas cap . The pipes that attach to the muffler were broken off at the muffler a few weeks ago , and I have a possible broken manifold bolt so I’m wondering if it’s a clogged catalytic converter ? Any help would be appreciated
It only did it that couple of times. I parked the truck for like a week or so before I could get a chance to mess with it. Secured the air box becuase it wasn’t sitting right over the throttle body , cleaned the air filter and drove the truck for about 20 minutes . No issues . Check engine light went off.I just had that same issue happen to me on my 2003 Ram 5.7L. I was close to home so dropped truck off and took grandmas car to work (that was fun). Came home and took truck on test drive and ran fine. I've had this happen a couple of times. I feel like it's an electric issue. Any ideas?
Is yours doing it all the time or is it sporadic like mine?
Sent from my SM-G965U using Tapatalk
Thanks man. Yeah I did. It had a code and I thought I’d check some things out before I got it hooked up on a diagnostic tool. Secured the air box that wasn’t a little wonky , cleaned out the air filter. Was driving to get the code checked and the truck drove/ shifted fine . Check engine went off tooI know you've checked to see if the fluid is burnt, but have you actually checked the fluid level in the transmission yet (with the engine running, warmed up and in Park or Neutral) and also, any codes thrown? Sounds to me like low fluid or possibly motor is in limp mode from some other issue.
