cynlaker
2011 Ram 1500 5.7 Won't start . Read article on here & used info to test mine. Very low voltage 1.5 volts & varied on fuel pump fuse 25 . Pushed meter lead on it
& closed fuse cover on lead to hold in place . Got 12 volts & truck started. shut off & tried again. Low volts & won't start. After a few cranks got 12 volts again & it
started. Shut key off & 12 volt showed on fuse with key off . Swapped relays , no change. Hate to replace fuse integrated module , cost & not sure that is the problem.
Already spent a 12 pack working on it. Any ideas ?
