XD Addict sizing
T-rumble
Hey all,
I've been on the forum awhile, haven't ever posted because I use the search function and find most of my answers, but this time I'd like to have some more specific help, and maybe a pic request if anyone has what I'm looking for.
I have a 2011 CCSB 1500 4x4 and I'm trying to figure out what the proper fitment would be for XD Addict rims in 18x9. They have two options on 4wheelparts. 18 offset, 5.71 back spacing and -12 offset, 4.53 backspacing.
I should also say that I have a 2 inch leveling kit that I haven't installed yet. What's the largest tire I could fit with just this? I want to get Nitto Terra Grapplers.
Any help that anyone can offer me would be greatly appreciated! Thanks!
Also if anyone has a Black 4th gen 1500 with these rims in black, please share a pic!
quietpeen
2021 TRX
Hellcat
did you search in exterior for this? That's where threads on wheels and tires are.
Both those wheels will fit. The +18 mm offset is basically the same as the stock 20's. the -12 offset will stick out more giving you more room to run wider tires.
TexasNav
T-Rumble,
I have been looking at the same setup with the addicts. Look at this thread, http://www.ramforum.com/f41/18_xd_s...me_|_bushwacker_|_20%_tint_|_bilsteins-36782/
Has the addict with the -12 spacing and you can see how good you like it. Superlubricity did a good job getting the angles on the shots to see what is important. I believe you would be able to get 35s with just a level kit, but I would do a fit check before you went that route.
Soundwave
Get the -12 offset. Even if you don't get a wider tire right away, it leaves the door open for you later.
I had a leveling kit with 35s and it was just fine. I think the -12 addict is a 10" wide wheel, which puts it at the same backspacing as a 0 offset on a 9" wide wheel.
