York or Sanden?
whteglve
Winston-Salem
HEMI 5.7
I'm considering adding an onboard compressor. I'm leaning towards engine driven as well. That brings me to my question. Whould you go with a York 210 or a Sanden style compressor? Why would you choose one over the other?
I'm not considering any 12v compressor at this time.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I've run both. Main advantage with the York is it has a crankcase for oil, where the other style does not so you'll need a lubrication system on the intake (suction) side then a separator on the discharge (pressure) side.
The downside of the York is it's size. That's why on my Samurai rock crawler I used a stock AC compressor with a separator that I can drain back into the suction side. The York sits on a shelf.
