2011 Bluetooth problems
Rustyraindog
Spanaway, WA
2011 PW
My S21 will connect and make phone calls no problem, it used to play music no problem also. Now the music feed cuts in and out every few seconds. It does not matter if I am streaming from youtube, Pandora or Spotify as it just keeps cutting in and out. Supposedly my radio software is up to date. Anyone have any suggestions?
Administrator
Have you tried deleting the Bluetooth pairing on both phone/radio, cycle power on the phone and then re-pair the phone.
Also check any audio and/or codex settings. Be sure the phone and apps are fully updated
jawzs2
South Jersey
What radio do you have? down on the lower right corner there's a three letter code, Could be RES, REQ, RBZ & RHB or RER, RHR. the first four have a separate external uconnect module, the last two is internal. There was an update released for the external module way back when for those to fix choppy streaming. Let me know what radio it is and if applicable, I'll dig thru my old files to see if still have the info.
EDIT: Found the link where I got the info from, the download link on the page still works. I'll PM you the link since you can't post links to other forums.
Rustyraindog
Rustyraindog
Spanaway, WA
2011 PW
I have an RBZ and my truck was built 9-10 so according to the jeep thread, mine should not need the file update. I am going to unpair and try to pair it again. Crossing my fingers! If mine has an external BT module, is it possible to replace it with a more modern version?
Rustyraindog
Rustyraindog
Spanaway, WA
2011 PW
Just tried all that with no luck, streaming music still cuts in and out every 4-5 seconds. Everything is up to date per my phone and the Ram site when I checked my radio software. Phone is a Galaxy S21 Ultra.
jawzs2
South Jersey
hmmm - according to what i read, it should be appliable, and yes, that radio does have the external module. You can replace it with a later version, but make sure it's for a high speed bus. they make two versions, low and high speed.
"It's for 2011 vehicles that were built prior to 6-1-2011 and have the Mitsubishi radios (RES, REQ, RBZ & RHB) ONLY"
Rustyraindog
Rustyraindog
Spanaway, WA
2011 PW
So mine was built in September of 2010 and I should try the update file. It is wierd that the phone works with no problem, it is just when trying to stream audio. I will try the patch you PM'd me about.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The exterior Bluetooth Module should be behind the passenger side front seat Kick Panel
