6.4l- 87 vs 89 vs 93
MADDOG
Out Exploring Arizona
92. Getting a bit better mileage, engine runs much better, now tuned for 92 by HF.
Dmopar74
I run 89 in my stock 6.4
UrbanKnight
generally, unless you are tuned for a specific octane, there will be no difference that anyone will notice...
Andrew09HEMI
I ran 87 first cause that's what the dealer put I then I filled with 93 and there's a noticeable difference. Not night and day but if you're paying attention to idle, mds activation and slight throttle response it's definitely there.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Been discussed many times.
Cliff Notes is the engine adjusts when running either 87 or 89 octane. For commuting and general use, 87 is fine and the math is not there to run 89 octane for any MPG gains.
Only time 89 shines is during heavy hauling or trailer use. Even then, butt dyno using 87 octane will never know the difference.
River19
"Live" VT, Work in MA/RI
Hemi 6.4L
I put so few miles on this rig and when I do it is 70% with a trailer or load that I just rock the 89......truck sees only about 7500 miles per year currently so the $ difference is laughable.
Tundra has done fine for 230K miles on 87, Our Lexus gets ~91 as I mix it up and our Rav is always 87........never saw much use for true premium fuel in modern untuned vehicles......
As others have said, if you plan on tuning it then by all means get a fuel specific tune like MD and his 92 tune etc.
smurfs_of_war
Swift Current, Saskatchewan
Began with 87. Switched to 89 for 6 tanks to see if I noticed any measurable benefits. None found, switched back. I am not in the habit of literally burning money.
Sent from my SM-G925W8 using Tapatalk
drittal
E. Montana
My favorite gas station used to have 89 for the same price as 87 and it actually had less ethanol than the 87! Their pumps blend 91 with 87 and their 91 is ethanol free. So I always ran their 89. If I was towing I got at least 89.
nukegm
6.4 hemi
mid grade. in colorado its 87. tried premium didnt notice anything....happy new year comrades!
reloaderguy
Oregon
2016 Power Wagon
I bought a tank of 91 ethanol free and saw an immediate 1.5mpg improvement on the highway. It was $1.20/gal more than cheap 87 so I bought exactly one tank.
SwollenMonkey16
SwollenMonkey16
Thanks for the feedback fellas. It's almost time for me to fill her up for the first time so just wanted to see what you guys have done since you already have the beast
SouthTexan
408 CTD
Unloaded, I say run what ever octane you think your truck runs better on and you are comfortable paying for. It's your money do with as you please even if there might not be that much of a benefit. Towing 5k or more especially on a hot day, I say run 89 at a minimum.
I know my old F150 Ecoboost changed timing when 91 octane was added and upped the power to 15 more hp and another 10 lb-ft per Ford. Not sure how much power it adds to the 6.4L(if any), but at the very least it will deter it from knocking or pre-igniting when pushed hard which will keep the ECM from pulling timing and lowering power output.
