Yes!! I'd join this party and bring the beer!!JB, any chance you could add a full parts list to this? Better yet, I'll send you my stuff and you could work that voodoo magic on my parts
How did you wire yours?
so would all the power leads from the accessories feed into the bottom of the fuse box?
Over the year I started adding more and more electrical items to my truck so I decided to add the AEV 6 position switch pod part number 30601000AA to the dash. I designed a schematic, ran it by @IRSmart a few times to check my plan and started ordering the parts.
https://secure.aev-conversions.com/shop/products/interior/switch-pod-for-ram-trucks
View media item 25418
View media item 25404
View media item 25405
The power distribution box is made by littlefuse HWB60 and worked well. I ran the trigger wires inside the fender like the other oem wires are.
http://www.littelfuse.com/products/...modules/hard-wired-pdm/hwb60/pdm21001lxm.aspx
View media item 25414
View media item 25416
View media item 25417
The switches are from OTRATTW (Over The River and Thru The Woods)
https://otrattw.net/LOWER-INDEPENDENT-LIGHT-UPPER-DEPENDENT-LIGHT-SWITCH-ONLY/
The rockers are Contura XIV, they have a good feel to them and have a "separation" molded in to distinguish upper or lower.
https://otrattw.net/CONTURA-XIV-ROCKER-ONLY/
I used @kad method of entering the cab via a rubber boot.
http://www.ramforum.com/threads/ins...nning-wires-into-the-cab.117923/#post-1696482
View media item 25415
I routed the wire bundle behind the head unit and up thru the top of the center stack. I then added the mating connector to allow easy removal of the switch pod.
View media item 25419
View media item 25412
View media item 25409
View media item 25410
View media item 25411
View media item 25413
View media item 25407
View media item 25421
If your asking me?.....I posted a schematic on the first post
can you teach me how to read it?
I see the red terminates at the fuse block for power, and you've used a separate color from the relay to the accessory. I guess what I'm after now is a picture of the multi-color wires into the fuse box then.
