Here are the factory LEDs with red Lamin-x. I also filled the always on pin-hole light with Lamin-X and the OEM foot-well lights.
If you don't have factory LEDs or if you do and want to replace the bulb anyway you can use these which are cheap and good accessory bulbs.
Use this bulb if you DO NOT have factory LEDs
Cutequeen 4PCS LED Car Lights Bulb Red T10 3528 20-SMD 194 168 (pack of 4)
https://www.amazon.com/dp/B00B2HHDS2/ref=cm_sw_r_cp_apa_KzxKAbKE6KSWP
Use this bulb if you DO HAVE factory LEDs (low profile so the lens/diffuser will fit back on) and want a brighter bulb. This only comes in white from what I see so you will still need to tint the lens with a small square of Lamin-x for a red light...
Cutequeen 10pcs LED Car Lights Bulb White T10 3528 8-smd 194 168 (Pack of 10)
https://www.amazon.com/dp/B00GZGW47U/ref=cm_sw_r_cp_apa_VxxKAbE55T7HT
If you need Lamin-X go here and find the cheapest universal sheet of the color you want.
https://www.lamin-x.com/Universal-Film-Covers-s/1513.htm
