CostaRam
I searched the hose from the PCV valve to the throttle body.
There is a hose going from the oil filler to the air cleaner, but the pocket in the air cleaner is clean.
Driver side is the vacuum hose for the brake and another thin hose,
passenger side has a thicker hose coming from the rear of the engine and enters the throttle body on the bottom.
Is the pink marked hose in the attached picture the PCV hose where to install the catch can?
If so, could it be that the square box with a plug above is some kind of a oil separator? If not, what is the purpose of it?
Chris
Chris
