CTD shaking/vibrating... DV's?
Discussion in 'P Pump' started by Montgomery Farms, Jan 25, 2012.
  1. Montgomery Farms
    Montgomery Farms Member
    97
    Oct 17, 2011
    Ram Year:
    1994
    Engine:
    5.9L Cummins
    I don't know how many of you guys know 12V's but I have a 94.... The truck in my sig... When i bought the truck I noticed that the truck would start shaking or vibrating heavily in 5th gear when i get down around 40 MPH. I figured it was just because it was lugging it slightly. When i pushed into the pedal a little bit more it would clear up and power through it. I recently put 75 HP injectors in the truck from DDP and it has gotten a little worse. it will do it even at 45 MPH and when its cold even at 50 MPH, but it doesn't only happen in 5th gear now either. In 4th you can sometimes feel it but not as severe. It also seems to cackle a lot in the lower RPM range from around 1000 to 1400 but i think the cackle is just because of the exhaust that I am running... I remember hearing somewhere that Delivery Valves helps take away chatter (shaking/vibration?) with bigger injectors and didn't know if this was the same problem that they were talking about because it happened BEFORE i had my injectors too... it makes the truck more of a nuisance to drive, especially when the truck is colder. Any personal experience or knowledge is greatly appreciated!
    Thanks
  2. ramhunter9
    ramhunter9 Supporting Member
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    Struggling for fuel , you need a lift pump . Bigger injectors are going to make it worse ... If not kill the stocker . Sounds like the stocker was going south anyway .
    I think I told you this at one point :Wedgie:
    Now this is just a guess from riding in your truck . Putter putter sputter sputter ..I NEED FUEL
  3. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
  4. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    What I said but in a more technical term ^:Wedgie:
  5. Montgomery Farms
    97
    Oct 17, 2011
    Ram Year:
    1994
    Engine:
    5.9L Cummins
    Then wouldnt it get worse in the higher RPM range instead of clearing up? that doesnt make sense...
  6. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    With a load there is more need for fuel .
    Your truck NEEDS more fuel in lower gears than top end . Taking off from a dead stop requires more fuel as the truck / motor needs to get going . At top end it already has the mass moving so less fuel is needed .
  7. Rogan68
    Rogan68 Senior Member
    545
    Aug 26, 2011
    Lancaster, TX / Winchester, VA
    Ram Year:
    2001
    Engine:
    5.9L CTD 24v 6 hole Bolt-action
    does it smoke when you're experiencing this issue? If so, is it black or white/gray smoke?
  8. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    Greyish last time I seen it
  9. Rogan68
    545
    Aug 26, 2011
    Ram Year:
    2001
    Engine:
    That's definitely a fuel starvation then. Mine smoked gray when the lift pump was going out, and stuttered like hell.
    per Tapatalk on my EVO
  10. Rogan68
    545
    Aug 26, 2011
    Ram Year:
    2001
    Engine:
    Both my 12 and 24 valves did
Share This Page
