Gear swap on 09
MidwestJ
Illinois
generally speaking....
What would I be looking at ($$$$) for regearing an 09' 4x4?
If I'm correct, i do not have the welded in parts in the front diff like the newer rams.
I'm at 3.55 currently-lookin at 4.10.
I would definitely be paying a shop to do this. This is beyond my expertise.
Thanks
U&A
2016 3500 SRW
6.4 HEMI
3.55’s to 4.10’s is not a very big jump. Really make sure you know what your RPM’s are going to be at a given speed so you know you are getting the results want.
I went from 3.73’s to 4.88’s and run 35” tires and it’s perfect.
Here is a good link to see what you rpms will be at any given speed
http://www.grimmjeeper.com/gears.html
3.55's blow, great idea. Use that calculator to see what rpm you are in per gear, u&A just did his, what did you pay Kyle I forget? 2200? Once you see what rpm in gear at mph you can play with it and see with manual shift mode how that feels like before you randomly choose a gear set.
U&A
2016 3500 SRW
6.4 HEMI
2,300
That was front and rear, kept OEM carriers and got 7 quarts of schaeffers 75W140.
I assume a 1500 will be less as the gears are a bit smaller. I would say around 2,000- 2,200 without changing carriers
Pay attention to break in procedure as well. They don't have the same finish on after market gears as factory, they need to be broken in correctly.
2010 Infantry Vet
Butler pennsylvania
Is your ram a two wheel drive? Im not aware of any front 4:88 gears. Just the rear.
RLJ10X
Southern Indiana
4.10s on stock height tires.
2000 rpm = 71 mph
1600 rpm = 55 mph
I had 3.55s. They were awful. You'll like those 4.10s.
Reactions: U&A
M
MidwestJ
Illinois
Believe I’ve got stock height tires.
I’m running duratracs in the OEM size.
Man. $2k is a load :(
U&A
2016 3500 SRW
6.4 HEMI
4x4
6.4 hemi
SRW 3500
