Headlight Bulb Change
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
My project today was to switch my stock bulbs out for Sylvania Silverstars & Ultras. Here are the replacement bulbs you'll need.
picture.php
Here are the tools you'll need for the entire job: Cloth, Flat head screwdriver, 10mm socket/ratchet or wrench.
1) Remove the shoud. Probably the only thing I didn't take pics of is the radiator shroud/cover you'll have to remove. There are 6 plastic push clips that have to be pulled out to remove the shroud. I didn't stick the screwdriver under to pry it up because I didn't want to scratch the paint. I'm **** like that. I lifted the shroud on either side of the clip using both hands and pulled up until the push clips finally popped out.
2) Remove the grill. There are plenty of people that will tell you that they have no trouble with practice getting the headlight housing out without removing the grill. When I started to remove the headlight housing, the top bolt opened into the grill rear so I decided to take it out. There are 4 10mm bolts that have to be removed on the top of the grill. Once they are removed, there are two silver clips that hold the bottom of the grill in place. In order to release them you need to slightly lean the top of the grill (while standing in front of the grill facing the truck) toward you. There are two spring clips at the bottom (one on each side of the grill) that have to be popped out. That is all that is holding the grill. These are the pics of the bolts to remove.
picture.php
This is the retainer and spring clip that you are removing. This photo is of the bottom of the grill. Keep in mind while you are removing the grill that the spring clip is under the silver plastic retainer. All you will see when you look down between the radiator and grill is the top of that silver clip.
picture.php
This is where the spring clip is locked into. The hole just above it is where the plastic retainer is shoved into.
3) Remove the headlight housing. There are only two 10mm bolts and a plastic clip that you need to remove the headlight housing.
You need to remove a sliding plastic retainer clip that you need to access from an access panel within the wheel well. I turned my tire to the left as far as it would go to give me the most room to work. Likewise, I turned the passenger side as far to the right as it would go. This photo is of the driver side so you could see where the access panel is.
picture.php
Here it is closer. To open the access panel, you need to remove the same type of push clip that held the radiator shroud/cover. It's at the bottom of the access panel.
picture.php
Once you have it open, you'll have to reach in and feel around for a plastic slide retainer. The easiest way to find it is to feel your way along the fender, through a hole. Reach a bit higher and you will feel this SQUARE plastic piece you need. Once you find it, pull it down to release the headlamp housing. It looks like this and you can see my hand reaching into the access panel to give you an idea of how far you need to reach.
picture.php
This is what is locked behind the slide plate. If you don't get to it the headlamp housing won't come out.
The headlamp housing is ready to be removed. It's much harder to pull it straight out. The easiest way to remove it is to grab the housing from from both sides (so it doesn't fall and scratch your bumper) then swing side near the bolts (center of the truck) toward you (in the direction of the front of the truck) and swing it (the center part) out toward the side of the truck. The opposite side still in it's place. As it swings out you will feel it release and come out easily into your hands. As it comes out you will see the headlamp wires still holding onto the housing. The wires the farthest to the side of the truck are the amber parking lamps. Now is the time to change these if they are old so you don't have to go through this again in two weeks when it burns out. In this image you can see the smaller hole on the left with the light green color in it. That is where the amber parking lamp goes. Rotate it, to remove it.
picture.php
The next wire that will be holding on, the last one left, is the headlamp power source. If anyone is installing HID replacement kit, this is the power source you will need to connect to the ballast. To separate both clips apart you will need the flat head screw driver. First, slide the red retainer back away from the black pug. That is at the top of this image.
picture.php
Next, reach in with the screwdriver and lift the green tab while pulling the plugs apart. Try not to pull too hard on the wires. We don't want them to come out without the plug.
Now the housing should be free. Place it on a soft cloth to avoid scratches while you work.
There are two dust covers that need to be rotated and removed. That will expose the both bubs (high and low beams) to be changed. Referring back to this image, the lower bulb is the high beam (replacement bulb 9005) and the One on top is the low beam, you can see it in this image with the green color (replacement bulb H11). The bulbs need to be rotated to be removed from the housing and the retainer clips released to pull the bulb from the plug for exchanging.
To reinstall, follow these directions in reverse order.
I exchanged my bulbs with the Sylvania brand "Silverstar Ultra" because I wanted a brighter bulb. I live on a dark dirt road away from the city so I needed the extra light. I took some before and after photos. They are explained below.
The first pictures are the fog lamps alone. Top before (stock bulbs) and bottom after (Sylvania Silverstar).
picture.php
picture.php
Second set is of the low beam headlight and fog lamps combined. Top before (stock bulbs) below after (Sylvania Silverstar Ultra).
picture.php
picture.php
Third set is of the high beam. Top before (stock bulbs) and below after (Sylvania Silverstar Ultra). By the way, the dot on the right side of the road is a stop sign lol.
picture.php
picture.php
If you want to know the difference of the stock bulb to an HID (high intensity discharge) lamp replacement, the HID's are 300% brighter than stock.
To replace the fog lamps, all you need to do is look under the truck and behind the bumper. This is what you'll see.
picture.php
This image is taken from the driver side of the truck looking over to the passenger side. You can see the back of the fog lamp in white.
picture.php
Exchange the bulbs by rotating the bulb to remove from the housing and removing the retainer clip to exchange the bulb. Then replace it (replacement bulb 9145).
This image show the bulb removed from the housing.
picture.php
If this post helped one person out it was worth my time. Thanks for reading it!
quietpeen
2021 TRX
Hellcat
awesome write up man
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Very nice indeed!
Only thing to add / update? The green H13 plug that goes into the headlight (and is then split inside) is where you would get power for HIDs, if you had the duals. In the quad setup, power is obtained by the inner plugs (the H11 or 9005 ones).
But, holy hell, GREAT write up here!
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
smokin write up!!
Birddog
Birddog
West Palm Beach, FL
Very nice indeed!
Well sir you just added it and taught me at the same time. I've used plug and play systems that only need to e plugged. I've never had to split the wires. It's always easier when you don't have to pull out a volt meter.
Thanks to all for the likes and props. Like I said in the post, if I could help just one person it was worth my time.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Yeah, the 4th gen quads are a different animal. :D Most HID kits only go to 1 bulb (well, all do, lol) - and that connector goes to 2 bulbs. First glance is "wth are they doing here". But, I've seen this same idea on the new Chebby's too - but they don't have the wiring inside the headlights.
Birddog
Birddog
West Palm Beach, FL
I like that Ram put the wires into the headlights. It's a PITA to get the housings out but MUCH easier to work with the bulbs.
Goon
MA
Awesome write up. Looks like a PITA to change the bulbs. This will surelly speed up the process. Probably won't stop me from bleeding at least once though. I always bleed working on the truck!
Stroked
Beloit, Kansas
Wow! Great writeup! I wish this had been here when I changed my bulbs. Those plugs on the headlights are a pita.
MK12RAM
Georgia
Looks like I'm only going to change out the fogs, forget the headlights.
Sent from my ADR6400L using Tapatalk 2
Graygoose
Oklahoma
Convert, for now.
small
I can have my headlights out in no time, its easy!
MK12RAM
Georgia
I'm pretty happy with how bright the stock headlight bulbs are. If it was a reach and remove I'd do it but I'm just going to stick with doing the fogs. Maybe I'll grow a pair and try to do the headlights one day.
Birddog
Birddog
West Palm Beach, FL
Putting the silver stars in the dogs made a huge difference. Check out the first set of pics on top.
MK12RAM
Georgia
I'll do the swap in a couple of weeks. I told myself I would not start swapping stuff out with this truck, damn this addiction.
Graygoose
Oklahoma
Convert, for now.
small
How did they fit in the dogs?
:D j/k
JJP71584
Pgh, PA
Fantastic write up and if you guys are worried about getting to the headlights, it can seem intimidating but after you do it once you'll be an expert. Pulling the grille off and getting to white tab pushed up behind the headlights are really the hardest parts and its not that bad...just a whole hell of a lot of steps to swap a bulb out!
D33k
Las Vegas
Just do it, I can have both headlights and grille off truck in the time it takes my garbage men to pick up my street, (small street too) 8 bolts, 8 push tabs, 2 lock collars and done.
Birddog
Birddog
West Palm Beach, FL
:D j/k
Hahaha!! You got me. I posted that using Tapatalk with my iPhone. Damned autocorrect!! I meant "fogs" not dogs. Nice catch!
Graygoose
Oklahoma
Convert, for now.
small
just messing, yea, figured it was phone :D
