- Mar 20, 2016
- 10,790
- 16,924
- 2015
- 3.0 EcoDiesel
If you already have the 8.4, you just need the two harnesses from M² Mods to add the temperature and humidity sensors, there is an optional solar sensor for the dash also. You can order both sensors from AllMoparParts.com which is a forum vendor. Yes there is only one temperature sensor used in the dual zone set up. That will get you to the point of having single zone ATC.Sorry if this was already answered, I just couldn't find it.
I have a 2013 with the 8.4 mtc and I see that the "conversion" harness is mentioned. Do I need that if I already have the stock 8.4 or does this atc mod only work if I switch to the 2018 screen?
I would like to actually jump straight into dual atc like I saw in another post, but those instructions were for going from single zone atc to dual. Not from mtc to dual.
You might want to try that before committing to ripping the dash apart to replace the HVAC air box module. The only thing you gain with the dual zone is the separate adjustment for the passenger side.
I changed to the single zone ATC and more than happy with how it works.
