Inez Hotrods 4/6 Drop
Quicksilver337
South FL
2016 Ram R/T
I have the air lift bags in mine with 4 rungs cut out the rears. No problems with anything in the back, and I'm running the pro comp shocks that came with the kit. No complaints here. I aired the bags up a little bit, then drained them to where the ride height stabilized the air pressure, and that's what I'm using for added "bump stops". I don't bottom out unless I hit a really big bump going at a pretty good speed.
Do you have the 4/6 or 5/7? did you cut the coils?
ramittome
Gonzales, LA
The 4/6 kit and the 5/7 kit is the exact same. It's just a matter of if you want to cut the front springs to get the extra drop, and cut the rears more to match. They send you a 4/4 kit when you purchase it and you go from there. I left the front alone with just adding their control arms to give a 4 inch drop and as stated I cut 4 rungs out the rears to give me a 6 inch drop to match the front. Right now I'm sitting about 1/2 an inch higher in the rear.
Quicksilver337
South FL
2016 Ram R/T
I only purchased and installed the front control arms and the rear bracket. I already had the springs and shocks. I see you have a double cab so the spring would be different. I already cut two coils on the rear but still not level...thinking of cutting 1 more coil.
ramittome
Gonzales, LA
Yeah, at first I only cut 2 coils off, but was still almost 2" higher in the rear, so I cut off another 2 coils. Now I'm right at 1/2".
ramittome
Gonzales, LA
My install price was free as I did it myself with about 14 hours of work while drinking beer, lol!
I'm running 285/50/20 tires. Just a hair smaller than stock.
Ohninehemisport
Chicago
How are the front arms to install? Do they fit/line up perfect or do they take some force to get them in the mounts?
ramittome
Gonzales, LA
Mine tops a little wiggling to get them in the first time, but after riding on them for a few weeks, I removed the tops to adjust them a bit and them came right out and went right back in. The bottoms went in with no problems.
Quicksilver337
South FL
2016 Ram R/T
I get a thump from the front when I have the wheels turned all the way coming out from my driveway. There is a little dip from my driveway on to the street. I got to crawl under there and check it out. I've heard that some people get bump steer with these arms.
Quicksilver337
South FL
2016 Ram R/T
Hi Quicksilver337 what are your thoughts on the kyb shocks
funny you should ask...I haven't had a chance to install them been busy with other projects and it's too freaken hot and humid to work outside. Got to get me one of those 30" drum fans :naughty:
Quicksilver337
South FL
2016 Ram R/T
How in the world do You find anywhere to go fast with all that traffic down there? :crazy:
lol... not only the traffic, cops are ticket happy over here :crazy:
kidding aside we have some spots where we can test them out if you know what mean
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
2 rams and a chevy
Hey got r/t as well looking to drop it how does the rear wheel center I the wheel housing?
Ftank
