RASelkirk
- Apr 20, 2018
- 236
- 116
- Location
- Port Neches, TX
- 2018
- Hemi 5.7
Was looking to see if I could display the current gear somehow while driving and found out - yes you can. But, it's kinda flaky. You can use the steering wheel gear control to select 8th gear and that displays prominently to the right of the cluster gear display. Very faint and just to it's left, is the current gear. Works that way until you cycle the ignition. Too bad RAM didn't have the forethought to reverse the "highlighting" and placement effects so the actual gear was bright and the "max" gear dimmed...
Russ
Russ
