Is this 2005 a special edition?
EldoEsq
First post! Have been looking for a nice clean Hemi 4x4...just found this 2005 with 56xxx on the clock. Not a scratch on it and runs like a champ. Asking price is 15k...which I thought was reasonable based on the condition.
Question though...I am pretty sure it is not a Daytona, but it has the sane hood and front airdam. There are also no emblems at all except for the hemi badge. At first I though the last owner might have done these changes, but I saw another on the road like it.
Any info would be appreciated!
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Run the VIN to see what it had coming from the factory. The driver rear door looks off, but hard to tell in pictures. I'd check for body repair and repaint.
MyOhFive
HEMI
No, it may have come stock with that hood. It's a non functioning "ram air' hood but that's an SRT10 front bumper. Someone swapped them out at some point.
The only special editions for 2005 were the Daytona or the Rumble Bee and that truck is neither.
However that def sounds like a solid purchase to me tho! good looking truck regardless
ST-8
Yea that paint looks off on rear door
Redtruck-VA
Virginia
A friend of mine found a low mileage truck that was incredibly fresh with super paint. Turned out it was a roll over that had been ******* in repair for three years in the back of a body shop. Nothing wrong with the truck but it had been pieced together during the repair.
quietpeen
2021 TRX
Hellcat
like others have said....no it is not a special edition. Just an SLT or sport with the hood scoop and srt-10 bumper added
axemann030773
Very nice. Get it. And welcome:)
05daytona
It's definitely not an SRT-10 hood. The SRT-10 hood scoop is not bolted on, it's molded into the hood. The scoop looks too long to be a Rumble Bee, so I would guess it's an aftermarket piece.
USMC1188
SW Ohio
None
Truckless...
Yep, that's the same kind of hood scoop they put on the Rumblebees. The bumper is from an SRT10 though. It looks like it has also been debadged by the previous owner. So to me it looks like the previous owner did some basic mods to this truck, and like everyone else, maybe repainted some.
WhiteExpress
Midland, TX
I'd guess it was wrecked and rebuilt m'self.
Doesn't mean it's a bad truck, but you might want to take a close look at things.
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
Yeah id run a car Fax On Something On It just to get a little more into the back ground of it history cause that back door has been painted
RAtmosphere
Bartlett, Tennessee
2004 3500 Dually
5.9 Cummins - 12,800 original miles
Check that rear doors jamb and all the jambs for a tapeline or overpspray....telltale sign of a repaint....
E
EldoEsq
Waiting for the financing to go through by my credit union!
The carfax came back completely clean...I guess thats a good sign. The carfax states that the model was an "ST/SLT" with the 5.7 and 4x4.
Will definitely take a closer look at things before i sign the dotted line, hopefully no real issues!
Redtruck-VA
Virginia
I'd run the VIN for a build sheet to see what it originally came with. The dealer should have it available.
E
EldoEsq
Great Link!
Equipment Listing
Vehicle Description 2005 DODGE RAM SLT 1500 QUAD CAB PICKUP
Monotone Paint
136 Amp Alternator
4 Wheel Disc Rr Anti-Lock Brakes
Front Height Adjust Shoulder Belts
Next Gen Multistage Front Air Bags**
Floor Covering Carpet
Front Floor Mats
Passenger Assist Handle
Rear Underseat Compartment Storage
Overhead Console w/Trip Computer
All 5-Speed Automatic Transmissions
205MM HD Front Axle
Corporate 9.25 LD Rear Axle
Tinted Glass Windows
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
Remote Keyless Entry
Air Conditioning
Dash Liner Insulation
Floor Tunnel Insulation
Route 57 - CSX & NS, Ridgefield, NJ
Instrument Cluster w/Tach
120 MPH Primary Speedometer
STANDARD EQUIPMENT
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Glove Box Lamp
Halogen Headlamps
Cargo Lamp
Front License Plate Bracket
Ram's Head Badge
SLT Badge
4X4 Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Front Air Close Out Panel
Speed Control
Bright Silver Metallic Clear Coat
AM/FM Compact Disc Radio w/Chgr Ctrl
4 Speakers
Power Rack and Pinion Steering
4-Spoke Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
Non Adjustable Pedals
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6650#
U.S. Dealer Retail
Zone 32-New York
Four Wheel Drive (4WD)/(4X4)
6 FT. Cargo Box
Quad Cab
1500 Series
DR-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
New York Ship to State Code
New York Sold to State Code
Cloth 40/20/40 Prem Bench Seat
Dark Slate Gray
Light Group
Quad Cab Thunder Road Value Group
Sport Group
Trailer Tow Group
Mutually Exclusive Package
750 Amp Maintenance Free Battery
40/20/40 Split Bench Seat
Rear 60/40 Split Folding Seat
Front Center Seat Cushion Storage
Folding Flat Load Floor Storage
OPTIONAL EQUIPMENT
5-Spd Automatic 545RFE Transmission
Lock-Up Torque Converter
Elec Shift-on-the-Fly,F/Time T/Case
3.92 Rear Axle Ratio
Anti-Spin Differential Rear Axle
All Gas Engine
5.7L V8 HEMI Engine
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
All Vehicles W/Power Mirrors
Power Driver Seat
Power 6-Way Driver Seat
BRT. SILVER MET. C/C - Molding
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Fog Lamps
Body Color Front Fascia
Body Color Rear Bumper w/Step Pads
Body Color Grille
50 State Emissions
U.S. Emissions w/OBD 1
EVAP Control System
34 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Electronically Controlled Throttle
Heavy Duty Engine Cooling
Next Generation Engine Controller
All Radio Equipped Vehicles
Fixed Long Mast Antenna
P275/60R20 BSW All Season Tires
Goodyear Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
20X9.0 Aluminum Chrome Clad Wheels
Class IV Receiver Hitch
7 Pin Wiring Harness
Manuf Statement of Origin
2.5 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM: GS TRACKING: 60809M04
Customer Preferred Package 2TG
Customer Preferred Package 26G
Group Discount
Group Discount
Pre-Spec Vehicle Order Tracking
4X4 Tracking
Mobility Conversion Tracking
ISVL Tracking
Paint Order Code
