Connor r
I have a 2007 dodge ram 1500 megacab non mds and I’m stumped on what to I’ve gone through the entire top end of the motor. I started by doing my lifters, exhaust manifolds and new plugs and all new gaskets (made sure to clean everything) and my truck was still ticking so then I thought okay maybe timing chain because it has 176km. So I went in and changed the timing chain tensioner and oil pump. Still ticking…. I’ve done an oil change after every time going into the engine and I have royal purple 5w 20 right now with a k&n filter. Also I change the belt tensioner, serp belt , alternator , thermostat, and when I was in my heads everything looked mint even looked at the cam and looked good. No engine codes… can provide video if needed.
