Newb Ram Owner... Where should I Start?
B
Barrackus
Washington State
2007 Quad Cab
Called Moe's, explained to them what I was looking to do they suggested the Diablotune first, that I wouldnt really see the full potential of the addons until I hooked up the tuner... Also talked to them about the catch can, and because I do I have an internal PCV system I cannot add a catch can, but a way to help cut down on the amount of oil and hot air entering my intake is by adding a small breather filter onto the line from the oil fill to the intake and capping off the intake.. interesting that nobody has come up with a way to tap into the internal PCV system and create a catch can.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
There is a couple of DIY threads of catch cans done for the 3G's. Not sure if its on this forum or not. You can try non foulers in the rear sensors w/ optional 0000 steel wool to remove the CEL when running no cats. Been code free for 6-7 years using this method and still able to pass emissions (OBDII check)
Who ever does your CMR tune can also disable the rear sensors but most likely wont be in a i/m readiness state for emissions.
I would personally put 4.56's on your short list esp' if you are 2WD.
