Oil Change ?'s
ramflava
Albuquerque, NM
6.7 Cummins Turbo Diesel
I'm about to drive from Albuquerque, NM to Burns Flat, OK and back in the next two days. I haven't changed the oil since it came off the line and I'm at just under 6000 miles on the truck.
I'll be using Royal Purple and probably a mobil one filter.
My questions are:
I'll need 6 or 7 qts?
Is the filter I'll need the same for the 2013's as previous year models?
LB3711
Trumbull, CT
3.6L V6
your book or DVD that came with the truck should have fluid capacities in it.
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
7 quarts is correct, but I would definitely get 8. The filter for your truck is the same as previous year models.
ramflava
ramflava
Albuquerque, NM
Thanks everyone
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
ramflava
ramflava
Albuquerque, NM
What's the oil weight? 5w-20?
5w20 is correct. Royal purple Filters are much better then Mobil One filters too.
ramflava
ramflava
Albuquerque, NM
Cool. Got the oil changed with 5w-20 and used the Mopar filter.
ramflava
ramflava
Albuquerque, NM
I'm ginna look it up in a while, but can anyone tell me how to reset the oil gauge in the 2013's?
Xtreme545
Missouri
Should turn key to ACC and depress skinny pedal 3x
Sent from rock using chisel and hammer
ramflava
ramflava
Albuquerque, NM
Got it. Put it to run without actually cranking the engine. Then press gas 3x
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Have you pulled them open they are both Champion lab I am pretty sure same filter different colors.
$miley
ramflava
ramflava
Albuquerque, NM
$miley
I saw the Mopar one and figure "what the hell." It's the exact same one that came from the company and comparisons of oil filters alway end up going no where, everyone has an opinion. I've never actually research them, but I hear a lot about Fram filters being over priced for less part performance.
JimE
South Central Texas
Yup, the oil filter discussions have been going on since the first ones showed up over 80 years ago. Real fact is no filter is a guarantee of anything other than preventing chunks of gunk from being circulated. If a filter gets clogged up oil circulation just by-passes it.
Best bet is to frequently look at and smell the oil when checking oil. (everyone does check fluids regularly I hope) If oil looks off color (most synthetics excluded) or it smells bad, it's time to change. Makes no difference that the stinking manual recommendations imply you can go another thousand miles before changing, it's time to Change it.
Earlier in this thread, the discussion of viscosity arose and while it is true the manual says 5W-20 for most driving, it also suggest 5W-30 for different duty in differing ambient temperature conditions. Oil viscosity arguments/discussions have been going on since the first detergent oil appeared and intensified with the introduction of multi-viscosity lubricants. Word of advice if one is routinely using their RAM for serious pulling of heavily loaded trailers even 5W-30 may breakdown in hot summer weather and trash your cam and rod bearings.
$miley
According to my old research Mobil One filter was part cellulose and part synthetic and royal Purple was 100% synthetic media. Also, even though RP is built at the same place as many others, they have way better materials including heavier metal. Haven't you seen the youtube on them yet?
Here ya go.
