P0300 code
Kpc01
dealer is stating they can not pin point cause of random misfire by computer, been in twice. they are now saying I need to have the headers redone, any thoughts?
hemihustlin
Montreal
What did they say exactly was the problem with the exhaust manifolds? Is the truck stock?
I wouldnt let them repair anything unless they are sure that it will fix the problem.
I would take it to a reputable independent garage and get their opinion.
But first get ours, more details are in order :)
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
p0300 could mean almost anything..it's like a p0700 code..there should be followup codes to get to the root of the problem.. can you give us more details of your motor? any mods?
K
Kpc01
Sorry guys not headers the heads need to be redone, I have Torque pro app and only see the P0300 code there are modes, Here are some of the failures. I could E-mail the full report to anyone that wishes to see it.
MID:$31 TID:$95
- EGR Monitor Bank 1
Max: 227.67999% Min: 334.67999%
Test result value: 324.85999%
FAIL
MID:$3c TID:$86
- EVAP Monitor (0.040")
Test incomplete or dependant test failed
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
need a new egr valve? that can cause a misfire or hesitation..
K
Kpc01
I replaced the EGR valve two years ago, wouldn't I receive a code for it going bad? Is there a check I do do to test it?
RonJon '06
Southern Minnesota
Is it running/idling rough? How many miles are on the truck and how many on the spark plugs?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
the code you posted earlier was an egr error..how did that info come about?
K
Kpc01
I am able to pull codes with Torque pro app. It was one of the Mods in the test results.
K
Kpc01
It only idles and runs a little rough first thing in am and not all the time.Once I give it some gas it runs fine. Plugs have roughly 3000 miles on them I had new ones put June this year.
RonJon '06
Southern Minnesota
MID:$31 TID:$95
FAIL
MID:$3c TID:$86
I'm not sure if I'm reading these results right but it looks like it's finding a fault on Bank one. One of the things that can cause a p0300 is a bad front O2 sensor. You could try swapping the front O2 sensors to see if the error follows to the passenger's side.
K
Kpc01
any other thoughts guys?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
again, what plugs are you running? hemi's don't like platinums or iridiums..causes undo resistance in the coil packs and over workin them...
K
Kpc01
Not sure on plugs, I may have to pull one to see. You really think an o2 sensor would cause the P0300code?
K
Kpc01
I pulled a plug they are champion RE14 MCC4, shouldn't there be some sort of gel in the pack to help make contact to the plug?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
good, your using stock coppers so it rules that out...are your P0300's random or do they pop all the time? Are you seeing performance or driveability issues?
K
Kpc01
Starting to see more often, no issue other than slight hesitation in engine till I get going and it clears right up.
K
Kpc01
Here is a copy of the test results I ran today. I changed the plugs and cleared the light, I also put in a new ignition coil, plan on moving it around if light returns.
Test report:
MID:$01 TID:$91
- O2 Bank 1 Sensor 1
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.392V Min: 0V
Test result value: 0.392V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 65.535V Min: 0.647V
Test result value: 0.784V
PASS
MID:$02 TID:$81
MID:$02 TID:$82
MID:$02 TID:$83
MID:$05 TID:$91
- O2 Bank 2 Sensor 1
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Max: 0.392V Min: 0V
Test result value: 0.372V
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
Test result value: 0.745V
PASS
MID:$06 TID:$81
MID:$06 TID:$82
MID:$06 TID:$83
MID:$21 TID:$92
- Catalyst Monitor Bank 1
MID:$22 TID:$92
- Catalyst Monitor Bank 2
MID:$31 TID:$93
MID:$31 TID:$94
MID:$31 TID:$95
MID:$31 TID:$96
MID:$39 TID:$87
MID:$3a TID:$87
- EVAP Monitor (cap off)
MID:$3c TID:$85
MID:$3c TID:$86
MID:$3c TID:$90
MID:$3d TID:$83
- EVAP Monitor (0.020")
MID:$3d TID:$84
MID:$3d TID:$85
MID:$3d TID:$86
MID:$3d TID:$87
MID:$3d TID:$88
MID:$41 TID:$97
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 165°C Min: 0°C
Test result value: 50°C
PASS
MID:$41 TID:$98
MID:$42 TID:$97
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 190°C Min: 0°C
PASS
MID:$42 TID:$98
MID:$45 TID:$97
- O2 Heater Monitor Bank 2 - Sensor 1
Max: 165°C Min: 0°C
Test result value: 45°C
PASS
MID:$45 TID:$98
MID:$46 TID:$97
- O2 Heater Monitor Bank 2 - Sensor 2
Max: 190°C Min: 0°C
Test result value: 40°C
PASS
MID:$46 TID:$98
MID:$90 TID:$28
Max: 16,384 Min: 26,640
Test result value: 65,520
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
MID:$e1 TID:$87
Manufacturer defined MID -
End of report.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I have trouble reading the diagnoses, but if we knew the hierarchy of the tests performed then we might know what test didn't pass or not performed keeping the other tests from being completed. Just a thought..
JustinRam1500
