I pulled one of the rubber boots off a coil, and low and behold the inside was covered in rust, so far I have managed to clean 5 of them and replace one. I will eventually will replace all, after I see if this might have been the cause. Thoughts???
No, I have a 5.7, just hoping the dealer is not right on needing the heads redone.
No, dont know how.
Sure do, I changed them and the ignition coils recently.
OK, if pressure test is good will that eliminate the valves and rings? If not how does some oil tell me I have a valve or ring problem?
