P0300 code
K
Kpc01
Great info, I will post results.
K
Kpc01
unable to get the engine to crank over good enough to get compression, I think the computir is seeing the coils unplugged and wont let it crank properly, I have strong battery.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
On my 03 I can crank the engine with the coils unplugged without issue. I think you have something else going on..
hemidup
Supercharged 6.4 Hemi
How hard is it to crank it over by hand? Meaning with a 21mm socket and 1/2" drive ratchet.
K
Kpc01
dont think I can, I think I need to put it back together and do them one by one.
Redtruck-VA
Virginia
If you can't turn the motor over using a breaker, then stop and pull the valve covers to inspect the valve springs. Maybe the dealer really did mean HEADS.
K
Kpc01
That is what they want to do is replace the heads. Wouldnt that also consist of checking and fixing any valve problem?
Redtruck-VA
Virginia
Unless the head it self is cracked or damaged, it is all about the valves otherwise.
K
Kpc01
Gotcha, not looking good, I will try some more sea foam in the oill see what happens. Looking like the dealer is right.
Redtruck-VA
Virginia
Magic potion to the rescue.... IMO, save your money for the repair.
K
Kpc01
Nice, Thanks to all for all the advice, if anything Truck is running much better, really appreciate it.
Redtruck-VA
Virginia
So the engine does turn over... and runs.. I understood it wouldn't turn over???
K
Kpc01
Yes it runs good, but when trying to do the compression test I remove coils and a plug from each cylinder, it will barily turn over. Thinking its the computor not letting it crank prperly. Does how slow it cranks going to affect the compressiom test?
Redtruck-VA
Virginia
It should spin freely with a spark plug pulled from each cylinder. I pull the fuse to the fuel pump and unplug the throttle body, then prop the butterfly open. The engine spins at least twice as fast as normal startup. Turn the engine over three compression strokes and record the reading. Move to next hole and repeat.
K
Kpc01
Mine doesnt, it will only turn over normal with the coils in, can I do the test by removing one at a time?
Redtruck-VA
Virginia
I suppose as long as you do them all the same.
RonJon '06
Southern Minnesota
When I did my compression test I removed one coil pack and spark plug at at time. Also because of the TIPM there isn't an easy way to cut power the fuel pump so I ended up disconnecting the fuel line and running it into a gas can. You could also unplug the injectors or prevent the injectors from getting fuel by holding the pedal to the floor.
