bdemutis
- Apr 8, 2014
- 152
- 7
- 1995
- 5.9l 360 gas
Yes it pinged under hard accel, just have to work with it. If your plenum is leaking it will ping even harder. There is no way to adjust the timing on our motors its all in the pcm, not to sure trying to over ride it would be wise.
If you install the intake it will also like prem fuel, most any mods go best with prem fuel.
The starting point for your year truck is the pcm if you can't or don't want to use prem fuel then don't mod it at all, it will only waste your cash and make you unhappy with your truck.
Edit: If you install the M1 no pcm it will bog at bit, you install the Hughes F1 and it will bog a lot, both will make you unhappy with the results.
So basically first upgrade should be a pcm and if I don't upgrade my pcm I shouldn't upgrade anything else. I guess my only choice is to buy the pcm and I wonder if using octane booster would work. I guess I could always upgrade the ignition and see if it does anything.
