Pcv valve/ oil catch can
lilwayne
OK IM New to the dodge forum but i have a quick question or if someone could post some pics if they have any.. ok where is the pcv valve located at on a 2007 5.7 liter hemi engine i cant seem to find it anywhere and also has anyone installed an oil catch can on there truck if so could u post some pics how u have the lines ran.. thanks wayne
CKH
Marietta, GA
5.9 Cummins
Tons of folks running a catch can here. The PCV is is toward the rear of the intake manifold on the passenger side and the hose runs from there to the front of the manifold. Do a search for catch can install and you will find pics.
Edit: Here is a pic of the catch can setup in my 2006 Charger. The pcv is in the same location on the truck manifold, you can see it toward the back of the manifold on the left side in the pic.
Edit again because I'm bored right now. You have to mount the catch can in the trucks with the Z bracket because of the clutch van in the trucks. Here is a link to a good post.
http://www.ramforum.com/f44/bt_catch_can-37499/
lilwayne
lilwayne
tht is a total different setup then my truck il post pics soon
Ramguy65
Alberta, Canada
This is where it is on my 09. Not sure if its in the same spot as yours. Its in the back of the engine bay. Looks like a cap with a hose going into it.
ST-8
I would think lilwayne would have enough dough to just pay somebody to do his pcvvalve?
lilwayne
lilwayne
[/ATTACH]
this is wat im working with i dont c any line tht looks like any of the pics u guys showed me thank tho for the help
lilwayne
lilwayne
bump for some help plzz
Sparkyy
Northern New Jersey
v6
The 3rd gens have an internal PCV valve setup so we cannot do catch cans on our trucks. Very different from the 2009+ truck and the older 2nd gen trucks.
That is why you cannot find anything out about it.
ST-8
If you look at your pic you can see you or someone did a egr delete. You can see where it's right next to pcv valve
ST-8
Sparkyy look at the op pics see how his egr has that block plate on the intake. I have a delete on mine as well. Never did put the clip back on tho
Sparkyy
Northern New Jersey
v6
So I see, don't know how I missed that as I recently changed my PCV valve and had to get a new EGR valve as well.
Edit: Not sure I understand why an EGR delete would be done on a gasser though.
lilwayne
lilwayne
OK THANKS GUYS FOR THE HELP cuz tht was gunna b my first mod for any car or truck but i guess there is no need for one on this year truck
