This is a fact. The retaining clip on the can body can be sloppy/loose and not give the screw a very good hold. You can pry the clip out and use a pair of pliers to bend the tang down so the screw gets a better bite.Today I do this gasket replacement, clean all surfaces from the old gasket, and put the new one on the light fixture and back on the cabin, but what I think is the real problem, the screws, only 2 of them ,widened a part,one was loose allready, so there is not enough pressure force to really squeeze the gasket evenly, not good design by FCA,can't do much about it,if you push harder, the fixture may crack, so on the end ,I sealed the fixture all around with silicone, hope this fix the leak.
Too late now,the whole fixture is sealed, if this won't stop the leak,then I may try.This is a fact. The retaining clip on the can body can be sloppy/loose and not give the screw a very good hold. You can pry the clip out and use a pair of pliers to bend the tang down so the screw gets a better bite.
Hope it holds for you. I cracked my lens from over tightening the screw. Thought I was good to go only for it to leak again from the crack that I never noticed. I purchased the Dorman replacement for half the price of the OEM and the seal on that leaked within a year. I feel your pain.Too late now,the whole fixture is sealed, if this won't stop the leak,then I may try.
