WillardBerg
Just opened my rear door RHS and found water on my right rear seat beside the headrest. Are there any known issues with a rear window seal leaking? On 2017’s
im pretty sure the back windows are known to leak. but the most common one is the third break light leaking.
Edit: Are you from Grimsby in the UK?
New OEM gasket won't be the long term fix, this thread here is the fix, rubber weatherstripping from Home Depot/Lowe's.Well,today I spotted a leak inside the cabin in my 2019 ram classic,right in the upper right rear corner, so most likely is from the third break light,now I am waiting for the gasket to come from Amazon, hopefully this will fix this problem ,thanks to this forum I know what to do.
Okay, that's fine, it won't be a permanent fix like the weatherstripping will, trust me I've done it twice.This new gasket is the one,that guys uses for replacing the original oem leaking gasket.
