Curious question, how many 1000 plus horsepower cars and trucks have you built in your lifetime? In the 1000hp range I have about 100, and 2000+ range about a dozen. Parasitic loss is linear not exponential so for the sake of argument on a truck you lose about 18% from the crank to the tires. So 150hp gain from a supercharger would add 123 rear horsepower. Thats a stout gain if you ask me.
Again if you are comparing a pedal curve to a forced induction setup there is a learning curve here that might be a bit too much to overcome on a numb forum where emotion cant be conveyed and people think because they are told they are wrong they are being attacked. This is exactly the opposite of that. At the end of the day speed is determined by power to weight ratio. So a new mustang crank Hp to weight ration is about 8.5lb per HP, our trucks to compare is 12.6 lbs per hp. So to make it the same we need 150% more Hp that comes to about 600 crank HP, and thats not a hard number to get to with a Turbo or supercharger and be as fast as a Mustang 5.0. Dont overthink speed, its a measure of power moving weight. At the same time you can shed some weight of the truck remove seats, door panels, carpet, bed and so on and achieve the same speed gain without adding HP
