- Joined
- Apr 28, 2012
- Posts
- 23,321
- Reaction score
- 45,110
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
I notice you are in Nebraska, and so am I. While we are cold weather in winter, we are 95 degrees and 90% humidity from May to September, so I have been reluctant to go to 0W30 year round. Hoping Burla can offer his opinion knowing that we go from 10 degrees to 95+ for many months here in Nebraska.
So look at viscosity index's, in some brands 5w30 might be thicker at operating temp, but 0w30 is almost as thick, plus because of modern oil specs they have better base oils. So it is a fallacy to think 0w30 wont be as thick at the end of an interval just because of winter rating. Those base oils give those oils "naturally" occurring cold performance, whereas other oils use more vii's which are useless or harmfull to an extent at the end of an oci.
So if your 0w30 has dexos, medcedes, and/or Porsche specs, they are stay in grande specs, so oil blenders make those 0 winter rated oils their best oil. I personally believe 0w30 may be the best oil for the hemi period, in hot or cold weather. This holds true across most brands of oil, now we know there are notable exceptions such as redline 5w30, but those exceptions are for hot performance not cold. We had rams with hemi tick knock cold with 5w30 and not 0w30, plus 0w30 had good enough hot performance to keep tick away in summer. Ram forum has proven 0w30 is a better options in snow states for the cold then 5w30 redline. Look up cSt or ask me when you pick an oil, and then I can point out what I am saying. PUP is another notable disappointment, as they don't even go with a 0w30.
If you get cold piston slap, then even 0w20 is a legit strategy. Again, people think 0w20 is super thin compared to 5w20, this is a complete misunderstanding of those oil weights. The only issue with 0w30, is trying to find it, lol. It usually is a great oil, and you may have to pay extra for the base oils.
