Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
Rampant
NJ
392 Hemi
Seriously if it doesn’t come off just use a cut off wheel
I will do that or plasma cutter if need be, but I'm going to exhaust all non-destructive methods first. I'd rather not have to damage and/or replace the latch if possible. Not much room in there.97acd1b57453f89732fa97fb711c13d7.jpg
Sent from my Samsung Galaxy S8 using Tapatalk
U&A
2016 3500 SRW
6.4 HEMI
Just thinking.
Flip the lock out so it’s perpendicular to the door (sticking straight out)... take a rope and wrap it around a lock a couple times so it keeps it from flipping back-and-forth and tie a knot on it so the lock is permanently sticking out then cut it off with a cut off wheel right down the middle of the lock.
It’s easy to say because I’m not there but its working great in my head right now!! In fact i just got it off.
Yup it worked.
Rampant
NJ
392 Hemi
Maybe CLR? I have had some luck soaking correded stuff in regular old glycol coolant, also. Last resort before the blue wrench migh be something highly caustic, which will eat aluminum like alka seltzer.
Great suggestions... thanks. I may try a couple if the current ones don't work. I may also try a little heat too... just a propane torch, nothing crazy.
Rampant
NJ
392 Hemi
Just thinking.
Yup it worked.
Haha... if it gets to that point, I will drag the plasma cutter out and hang on to the lock with a vise grip. Already played that one in my head too.
AFMoulton
Nuevo Mexico
I was going to say Blue Tipped wrench......but I’m late to the party
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Try baking soda tooth paste and vinegar use an old tooth brush after soaking.
Ramnewbie
I'm surprised you didn't have it soaked up with Amsoil heavy duty metal protector. That's what I used to use on mine, a little stiff slow operation in the winter but never had corrosion problems.
Sent from my XT1650 using Tapatalk
Rampant
NJ
392 Hemi
I should have and will from now on for sure. Had I known I'd have to drive 30 miles through a salt mine, I would have. Lesson learned.
Well, I do think the innards are aluminum. Def not stainless and not ferrous. I used a small pickup magnet on it.
I tried PB, liquid wrench PO, Amsoil MP, and finally the little blue wrench. Still can't even get the key in past 1/4 of the way. I soaked it with all those and wrapped it with a rag. I'll let it sit over night and see what happens.
I do have a set of 36" bolt cutters but I don't think I can get them in there. At this point, I'm thinking the plasma cutter will do the least damage because it is recessed, so I can get behind it and direct the plasma outward and away from the door. I may resort to that.
Thanks for all the suggestions!
AFMoulton
Nuevo Mexico
Have some one video that **** if you do it! I wanna watch!
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Found this survey surprising. M1 in first place. Must be a reason. I guess PUP is in others.
U&A
2016 3500 SRW
6.4 HEMI
Mobil one is on the shelf of basically every oil supplier in the US. The have the market pinned down.
Thats why. Name recognition. Yes its still good oil. Great...? No.
You should hang around more. This thread is informative many ways
R.L.K.
Bristol , Tn.
Did you try heat ?
Maybe a heatgun in an attempt to expand the internal parts and melt the salt deposits inside , may take a few attempts . Once cool enough to touch then try water & vinegar.
Ramnewbie
I think the biggest falicy is the olm. Conventional/synthetic, good, better,best, I think the best thing any of us can do is change oil regularly, 3000 miles conventional, 5/6 thousand sythetic. No substitute for clean oil. The message on the olm instead of saying oil change required should say change you're oil stupid.
Fitz-0518
Veteran 66-68
Central California
Except one. How to factually determine which of the top high end synthetic oils reduce wear, dissipate heat and protect rotating parts at start up. Respect the chemist and engineers who take the time to explain oil shear, drop point etc. I agree, this forum will eventually get those who want to know, our answer.
huntergreen
Might try graphite.
GottaBeKD
CA
Not sure if anyone suggested pressure washer with the finest nozzle attachment.
Worked in my head so your mileage may vary
Sent from my SM-G955W using Tapatalk
Ramnewbie
The only one I can think of that you haven't tried is sea foam deep creep. Have heard it's really good stuff but never used it myself.
