RodRam
Good to know, even at the 99 mark PPU seems to be at the top grade of oils, I was surprised it tested so much higher than the PP syn, since Pennzoil says the main difference is only in cleaning.
Well said , these tires are junk as well , LOL My wiper blades dead after 12 mo. ?No I disagree, it proves there are other viable alternatives other than oem (stock) products.
If you were a car manufacturer, would you offer the best the auto world has to offer on millions of vehicles? If I wanted a profit margin even close to profitable,I wouldn't.
oil ,batteries,tires......even the wiper blades are just enough to get by.......aftermarket products are superior. Just look at the battery, any battery person will tell ya the batteries are not 5 year batteries, they crap out 3-4 years down the road for a reason. Some last longer depending on other factors, heat/cold.
This thread cracks me up. It proves the masses will use anything but stock recommended products. If MOPAR went to royal purple folks would hate it. Stick to the factory recommended oil and stop overthinking it. Hahahahaha
$43.05 for a 5Qt jug! Really! $36.59 if I subscribe... Ridiculous!
Just goes to show WM is a awesome place to buy Oil! If they stock your flavor!
Lets go back in time a bit. The year 2003.
Ram 1500 hemi owners manual.
5w30 and :gasp: 10w30! What were they thinking those crazy manufacturers
Next, the year 2006. The introduction of MDS.
Now 5w20 is somehow the best choice across all temperature ranges and "improves low temperature starting and vehicle fuel economy"
Im pretty sure that if you took two hemis and put them in the cold room at say -25 celcius, one with PP 5w20 and one PP 5w30 they would both start identically. Remember that 5 is the winter number.
And again the difference in fuel economy of 5w20 vs 5w30 is measured in decimals. It looks good on paper but the consumer will never see it.
Now to 2014
Now if you are unable to procure 5w20 5w30 is good if it meets fiat standard. Which, at a glance, seems to be euro equivalents of our normal 5w30 syn (valvoline syn power, castrol magnatec, shell helix, et cetra)
It doesn't even say to change it back at the next oil change lol.
Also the hd trucks with the 5.7 and a GCWR of 14000 lbs or more should use 5w30 all the time.
So, in conclusion, you can all use whats on the oil cap if you like but that doesn't mean the engine was designed around 5w20 lol
Thank you for enjoying my presentation
I don't believe the 5.7 in the 2500/3500 has MDS but I'm 100% on that...
I'm just throwing this out there!
Does the 2500/3500 Rams w/5.7L come with the MDS system?
I thought I read some where--->They did not come with the MDS...
Maybe I dreamed this...
LOL ! Better check that snow blowers operating manual , cause if it says to use a 20wt oil it's gonna blow more than snow , you should wear protective gear head to toe while operating it LOL !well to get back on topic ...sorta , I'm running m1 5w 30 in the sno thrower this year.
